13 years agoInstalling Quartus II 11.1 SP2 Web Edition to WinXP SP2 x64 Pro
I've been able to install Quartus 11.1 SP2 Web Edition on a machine running WinXP SP2 32-bit. However, when I try to install the same exact file to a machine running WinXP SP2 x64 Professional Edition, I encounter the following error almost immediately during the installation:
"WindowsError: [Error 5] Access is denied" After a bit of googling, I've learned it may be that this is related to running a 32-bit python installer on a 64-bit machine. Apparently there are some issues with 32-bit python accessing the registry in this situation. I don't know if this truly is the source of the problem, but I thought I'd throw it out there. Has anyone been able to install the 32-bit version of Quartus to a 64-bit version of WinXP? If so, how did you do it? Thanks, --tim
