16 years agoInstallation Problem in Quartus ii 9.1 SP2
I tried to install Quartus ii 9.1 sp2 on windows XP machine, SP3, NTFS partion drive (14GB Free space), 2GB RAM . On installation, files are extract to specified location on drive successfully, ...
16 years agoWhat quartus II 9.1 edition were you installed? Is it web edition or subscription edition? Can you check it (helpàabout quartus II) in quartus II main window? To successfully install the Quartus II 9.1 sp2 patch, you should have quartus II 9.1 subscription edition installed on your PC.
Besides, do you point to correct Quartus II 9.1 directory while upgrading to quartus II 9.1sp2? If quartus II 9.1 is available in that path, then I suspect your quartus II 9.1 software might be corrupted. In fact, I faced the exactly similar issue previously. By uninstalling the QII 9.1 & reinstall QII 9.1, I could successfuuly installing QII 9.1sp2.
