15 years agothanks kaz for the suggestions.
I already use a reset sequenzer that resets the design asynchronously and releases the reset synchronously. The resets of the different clock domains are released such that the next component starts to work after the previous has been reset. where can I find this "don't care setting"? Does it affect only registers? I've been using SignalTap to debug the design, but I recently removed it as it will alter the timing behavior and make fitting the design more difficult. kind regards
