11 years agoInserting SignalTap without re-routing design
I need to examine some internal signals in an existing FPGA design that was not set up for incremental compile (no design partitions specified for incremental compile). Is there a way to add a signa...
11 years agoHi Rysc
So I finally got signal tap in a separate partition. Basically it required 3 compilations. Here is what I did. Compile 1: I had compiled the design and decided to tap it for debugging. Compile 2: I created a partition for my design. In Project Navigator window I clicked on Hierarchy tab. Selected the module that I wanted to preserve. Right clicked on it and selected Design Partition-->Set as Design Partition. Now I could see my module in Design Partition Window. I changed its Netlist type to Post-Fit. Compile 3: Now I added a signal tap to the project. I can see the design being preserved in the reports now. Question Is it possible to view Pre-synthesis nodes in signal tap using this method (Im trying it out right now)? The signals that I want to see are not visible in Post fit mode. Thanks for your help
