11 years agoInserting SignalTap without re-routing design
I need to examine some internal signals in an existing FPGA design that was not set up for incremental compile (no design partitions specified for incremental compile). Is there a way to add a signa...
11 years agoSmart Recompile just skips modules if they're unnecessary. It's not very useful.
You always have a partition called Top, so just set that to Post-Fit. By default, Signal-Tap is put into its own partition and therefore won't affect Top. You need to tap post-fit nodes though. (Also, if you're able to try Rapid Recompile, that is supposed to work in this case too, preserving as much of the design as it can)
