13 years agoInput/Output constraints
I've inherited a design that has no input/output constraints. The Quartus compiler flags the inputs and outputs as not having constraints assigned. I was wondering: if no input or output constraints are assigned, does the compiler assume it has a full clock cycle to route the signal in the FPGA or does it use any criteria at all? Thanks, Grady
