10 years agoinout wire logic, quartus15.1, error
Using Quartus 15.1 I have the following issue, when I'm using this construction - inout wire logic [31:0] SIG1; - it is working correctly, but when I define logic [31:0] in typedef into ...
10 years ago --- Quote Start --- `wire logic` is legal SystemVerilog. wire is the signal kind, and logic is the data type. The other kind of signal is var for variable. This syntax was added in 1800-2009. To be backward compatible with Verilog, logic is the implicit data type for a wire. SystemVerilog allows other data types like structs and enums on wires. --- Quote End --- Thank you. I was not aware about this. Cheers, Bhaumik
