10 years agoinout wire logic, quartus15.1, error
Using Quartus 15.1 I have the following issue, when I'm using this construction - inout wire logic [31:0] SIG1; - it is working correctly, but when I define logic [31:0] in typedef into ...
10 years agoHello,
It's true that Quartus 15.1 supports package and user-defined types. Could you share your entire code? ( File which contains package and another file which contains your port declaration.) Also please post full message for your error. Thanks, Bhaumik
