inout PIO value change
- 5 years ago
Hi Mark,
Pertaining to the question earlier on the output buffer does not reflect the changing of the input buffer, it is an expected behavior. The hardware logic in the PIO is separate for reading and writing the data register. Reading the data register returns the value present on the input ports (if present). Writing data affects the value driven to the output ports (if present). These ports are independent; reading the data register does not return previously-written data.
For the self clearing bit, you may select "Enable individual bit setting/clearing" when you generate the PIO IP. This option is available for the output register only. When this option is turned on, two additional registers—outset and outclear—are implemented. You can use these registers to specify the output bit to set and clear.
KhaiY
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
KhaiY
Hi
Have a PIO buffer created with platform designer, connected to PCIe bar. Need to implement self clearing bit - PC writes "1", then next clock (or couple of clocks) this bit have to be self cleared. Please advice how to implement.
BR,
Mark.
