8 years agoInout pin Warning
Hi, I am using Quartus version 17.1. I am receiving this warning message: Warning (12620): Input port OE of I/O output buffer "fx3_dq[1]~output" is not connected, but the atom is driving a...
8 years ago --- Quote Start --- You can't have internal tri-states. They can only be at the top level. Is slwr_loopback_1d_ your oe signal? --- Quote End --- Okay, I will move the assign to my top level instead. Is it because tri-states only apply directly to the FPGA pins?
