8 years agoInout pin Warning
Hi, I am using Quartus version 17.1. I am receiving this warning message: Warning (12620): Input port OE of I/O output buffer "fx3_dq[1]~output" is not connected, but the atom is driving a...
8 years agoHi,
Just implemented logic you have described in both pro & std but not able to get the warning mentioned. 1. Just delete the incremental_db & db folder and try.- Which edition of Quartus (pro/std) are you using?
- Attach the code & message log from Quartus.
