13 years agoYou Can use the uniform function, but not in a process. It has to be used inside an initialisation function. But the problem is going to be the seeds need to come from somewhere, and Quartus wont let you store the seeds between function calls (theres no problem with this in VHDL per se via shared variables, but quartus doesnt like it). So you end up having to use a generic anyway.
So the answer is No for synthesisable code.
