Info 276004 with ALLOW_ANY_RAM_SIZE_FOR_RECOGNITION ON
- 5 years agoSorry, I only included the files that have direct impact on the problem and didn't check, whether the project was able to be built this way. But I have found the problem: the ST channel input port, that is connected to the read address of the RAM signal, was not driven by the ST source. Now that I have added logic in the source component RAM is being instanced. I still wonder why this was the cause though, because both RAM's read addresses mentioned above are driven by this ST channel input. Maybe it is because the one that worked is an asymmetrical RAM and Quartus handles them differently. Either way, it now works for both of them. Best Regards, Florian
thank you for the quick answer!
Unfortunately I can not provide the whole project, but I added to the .qar all the files I think are necessary for the issue. (qsf, vhd, tcl, qsys)
Florian
Could you help to confirm whether there is files missing in the qar?
I can't run Analysis and Synthesis due to missing files. Not sure if I miss anything?
Try to duplicate the issue with the qar that was provided to confirm that it is duplicable, before attaching a new one.
Warning (12019): Can't analyze file -- file ../../core/ip/x_protocol/clhsPack.vhd is missing
Warning (12019): Can't analyze file -- file ../../core/fpga_top/sib_nmi_clhs_fpga_top.vhd is missing
- FHint5 years ago
Sorry, I only included the files that have direct impact on the problem and didn't check, whether the project was able to be built this way. But I have found the problem: the ST channel input port, that is connected to the read address of the RAM signal, was not driven by the ST source. Now that I have added logic in the source component RAM is being instanced. I still wonder why this was the cause though, because both RAM's read addresses mentioned above are driven by this ST channel input. Maybe it is because the one that worked is an asymmetrical RAM and Quartus handles them differently. Either way, it now works for both of them. Best Regards, Florian- RichardT_altera5 years ago
Great to hear that you are making progress!!!
Since the issue has been addressed, I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
