--- Quote Start ---
You can use simple 16 or 32 bit counter and output of this counter can be assigned to your output.For example,we can divide a frequency by 8 using 3 bit counter.You can assign msb of counter to your output which will stay high for four clock cycle and low for four clock cycle.
--- Quote End ---
The problem with that would be the low frequency I require .
My final time requirement ranges from 30 sec to 30 minutes.
I changed the code to the following , which still gives OUTPUT as always HIGH.
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use ieee.std_logic_unsigned.all;
entity timernew is
port (clk : in std_logic;
flag : out std_logic:='0' );
end timernew;
architecture behavioral of timernew is
begin
process(clk)
variable count : integer:=0;
variable count1: integer:=0;
constant int: integer :=(10**6);
begin
if(clk'event and clk='1') then
count := count +1; --increment counter.
end if;
if count = int then
count := 0;
else
count := count + 1;
end if;
if count1 > 1000 then flag <= '1' ;
end if;
end process;
end behavioral;
