15 years ago --- Quote Start --- Hi, no service packs installed. I used signalprobe, I deleted signaloprobes and after the signalprobe compilation they are not available and with the oscilloscpe I checked they are not routed, tried to change to post-sinthesis or surce file the block where were signalprobe. The Partition merge still continue to give the same warning so no way to recompile every time it uses the old postfit netlist to fit...I dleleted those partition, no way.... I need to go back to a previos relase o the project and start again, but i would avoid this in the future... Any suggestion? --- Quote End --- Hi, try to set all partitions back to source file. Does that solve your problem ? Kind regards GPK
