15 years ago --- Quote Start --- currently I am using 9.1 version --- Quote End --- Hi, any service pack installed? I tried to reproduce your problem with 9.1, but all is working. Do use signaltap with post-fitting nodes also ? Maybe I know now what happens to your project. I assume you use signaltap with post-fitting nodes. If you do that, you are ask whether you would like to set the netlist type to post-fit and the preserving level to Place&Route. This done for every design partition you touch. After running the project with signaltap you enable some signalprobes and run a signalprobe compilation. I found out that as long as you are using the netlist types source or post-synthesis and you changed the setting afterwards and re-run the project, all your signalprobes will be disabled ( you get a warning about that). You have to re-run the signalprobe compilation also. If one of the partition set to "post-fit" and you try to change one of netlist types Quartus will not allow that. You have to change all "post-fit" settings at least to "post-synthesis" and re-run the signalprobe compilation. Kind regards GPK Kind regards GPK
