15 years ago --- Quote Start --- Hi, it was the first thing i did, but the top level was source file and also trying to set again to source file nothing happened. The partition merge always gives the warning that to mantaini ECO changes (signalprobe) the new fitter netlist was not used but still uses the old. On the help the solution for this warning is no action!?!?! The project is "locked" and i cant do nothing. On the manual I found how to preserve the signalprobe, but did non find anything to solve this problem. I am in trouble... --- Quote End --- Hi, which tool version did you use ? Kind regards GPK
