15 years ago --- Quote Start --- Top Level is source file, the other are postfit. I want to change the source code in a block included in the top level partition but I can't. It seems the sognalprobe routing has fixed the top level as postfit, deleting the signalprobe pins they are not routed out, but the top level is always compiled as postfit.... What can I do? Tx --- Quote End --- Hi, open the design partition window. Under Netlist type you find which netlist is used for which partition. If the netlist type for the toplevel is "post-fit" change it by double-click in the cell and choose "source file ". Kind regards GPK
