15 years ago --- Quote Start --- Hi, I developed a project using incremental compilation. I used some signalprobe to debig the systems, and now i need to make a modification to the code and then recompile but the partition merge gives the followin warnings. Warning: Forced partitions to use the same Netlist Type setting due to Engineering Change Order (ECO) modifications that span multiple partitions Warning: Partition "Top" will use Post-Fit or Post-Fit (Import-based) Netlist Type -- Engineering Change Order (ECO) modifications will be discarded Warning: Previously generated Fitter netlist for partition "Top" is older than the current Synthesis netlist, but using the previous Fitter netlist because of the Post-Fit (Strict) Netlist Type setting what can I do to recompile the project? Thanks --- Quote End --- Hi, what kind of changes did you make ? What are your partition setting ( e.g. netlist type and preserving level) ? Kind regards GPK
