16 years ago
Incremental Compilation PARTITION_IMPORT_FILE
I have a design with has a incremental compilation partition with a wrapper for a imported synthesis net list inside of it.
Is this enough to allow the tool to bring in the file properly?
The script would go something like this
set_instance_assignment -name PARTITION_HIERARCHY -to | -section_id Top
set_instance_assignment -name PARTITION_HIERARCHY -to \"myEnt1:umyEnt1|myEnt2:umyEnt2" -section_id "myEnt2:umyEnt2"
set_global_assignment -name PARTITION_NETLIST_TYPE SOURCE
-section_id Top
set_global_assignment -name PARTITION_NETLIST_TYPE POST_SYNTH
set_global_assignment -name PARTITION_IMPORT_FILE
"..\\myEnt2.qxp" -section_id "myEnt2:umyEnt2"
set_global_assignment -name PARTITION_LAST_IMPORTED_FILE
-to "myEnt1:umyEnt1|myEnt2:umyEnt2" -section_id "myEnt2:umyEnt2"
Do I need the final PARTITION_HIERARCHY or is that overriding the PARTITION_IMPORT.
My initial guess is that the PARTITION_IMPORT already has a place since it is given a section ID.
But maybe the PARITION_HIERARCHY needs to be created with a section_id and then have a netlist imported into it.
Any explanation is appreciated.
1 Reply
    This is what I think makes sense.
    set_global_assignment -name PARTITION_HIERARCHY root_partition -to | -section_id Top
    set_global_assignment -name PARTITION_NETLIST_TYPE SOURCE -section_id Top
    set_global_assignment -name PARTITION_NETLIST_TYPE POST_FIT -section_id "myEnt1:umyEnt1"
    set_global_assignment -name PARTITION_NETLIST_TYPE POST_FIT -section_id "myEnt2:umyEnt2"
    set_global_assignment -name PARTITION_NETLIST_TYPE POST_FIT -section_id "myEnt1:umyEnt3"
    set_global_assignment -name PARTITION_FITTER_PRESERVATION_LEVEL PLACEMENT -section_id "myEnt2:umyEnt2"
    set_global_assignment -name PARTITION_FITTER_PRESERVATION_LEVEL PLACEMENT -section_id "myEnt1:umyEnt1"
    set_global_assignment -name PARTITION_FITTER_PRESERVATION_LEVEL PLACEMENT -section_id "myEnt3:umyEnt3"
    set_global_assignment -name PARTITION_HIERARCHY -to | -section_id Top
    set_global_assignment -name PARTITION_HIERARCHY -to "myEnt2:umyEnt2" -section_id "myEnt2:umyEnt2"
    set_global_assignment -name PARTITION_HIERARCHY -to "myEnt1:umyEnt1" -section_id "myEnt1:umyEnt1"
    set_global_assignment -name PARTITION_HIERARCHY -to "myEnt3:umyEnt3" -section_id "myEnt3:umyEnt3"
    set_global_assignment -name PARTITION_HIERARCHY -to "myEnt3:umyEnt3|myEnt4:umyEnt4" -section_id "myEnt4:umyEnt4"
    set_global_assignment -name PARTITION_NETLIST_TYPE IMPORTED -section_id "myEnt4:umyEnt4"
    set_global_assignment -name PARTITION_IMPORT_FILE "..\\myEnt4.qxp" -section_id "myEnt4:umyEnt4"
    set_global_assignment -name PARTITION_LAST_IMPORTED_FILE "..\\myEnt4.qxp" -section_id "myEnt4:umyEnt4"
