SCAND2
8 years agoIncorrect FPGA speed grade in "Stratix 10 external memory interfaces" IP core (Quartus Prime Pro 17.1)
Hi, at the end of the synthesis of a design based on a Stratix 10 GX Development kit I get the critical warnings in the figure. The speed grade defined in the IP is the wrong one. I'm facing the e...
BoonT_Intel
8 years agoYes, we confirm that this critical warning can be safely ignore.
This issue is fixed in 18.0 and above.
I tried the same step in 18.0 and this critical warning is removed.
*18.0 do not support device with suffix S1 (engineering sample 1), so I used S2.
