AAjit2New Contributor7 years agoIncorrect additional .sdc file causing compilation errors Hi I'm modifying an existing project call vjuartcomm, and I have added the .sdc file called vjuartcomm however upon compilation I'm getting the error "Critical Warning (332012): Synopsys Design Cons...Show More
IDeynContributor7 years agoHi AAjit2!If you attach the the project (qar for example) it would be much easier for the community to help you.--Best regards,Ivan
Recent Discussionsram retimingReset Release IP for Agilex needs Stratix 10 device files installed!Licensing ‘Know-How’ GuideTiming analysis - long combinational pathInvalid license key (inconsistent authentication code)
