AAjit2
7 years agoIncorrect additional .sdc file causing compilation errors
Hi I'm modifying an existing project call vjuartcomm, and I have added the .sdc file called vjuartcomm however upon compilation I'm getting the error "Critical Warning (332012): Synopsys Design Cons...
sstrell
7 years agoIf the project says vjatguart.sdc, a file by that name must be referenced somewhere in your project or your SDC constraints. Are you saying that in the Timing Analyzer settings, the only file referenced is vjuartcomm.sdc?
Try cleaning the project from the Project menu and recompiling.
#iwork4intel
AAjit2
7 years agoYes this is correct. So previously I was getting error in Timing Analyzer as well as Fitter. But when I changed the file in Timing Analyzer that error went away but the fitter error was persisting. Cleaning worked for me to remove the error from fitter, thank you!
