11 years agoInconsistency detected by ld.so: dl-close.c: 764: _dl_close: Assertion `map->l_init_c
I keep getting this message whenever I run Quartus (15.0) on most non-supported Linux distributions. The message does not seem to be fatal, but some tools/scripts will check the output of Quartus and...
9 years agoHi all,
I have Quartus 17.0.1 running on Ubuntu 16.04 64bit LTS. After doing a fresh installation I corrected the following 2 errors: Fix error 1: intelFPGA/17.0/quartus/linux64/libstdc++.so.6: version `GLIBCXX_3.4.20' not found (required by /usr/lib/x86_64-linux-gnu/libproxy.so.1) Failed to load module: /usr/lib/x86_64-linux-gnu/gio/modules/libgiolibproxy.so $ cd ~/intelFPGA/17.0/quartus/linux64 $ mv libstdc++.so.6 libstdc++.so.6.bak $ ln -s /usr/lib/x86_64-linux-gnu/libstdc++.so.6 libstdc++.so.6 Fix error 2: Inconsistency detected by ld.so: dl-close.c: 811: _dl_close: Assertion `map->l_init_called' failed! $ mv libccl_curl_drl.so libccl_curl_drl.so.bak
