11 years agoInconsistency detected by ld.so: dl-close.c: 764: _dl_close: Assertion `map->l_init_c
I keep getting this message whenever I run Quartus (15.0) on most non-supported Linux distributions. The message does not seem to be fatal, but some tools/scripts will check the output of Quartus and...
10 years agoAlso what is the output of e.g:
ldd /your/altera/root/quartus/linux64/quartus_cpf | grep curl Replace /yousr/altera/root with the root path of your Quartus installation.
