11 years agoInconsistency detected by ld.so: dl-close.c: 764: _dl_close: Assertion `map->l_init_c
I keep getting this message whenever I run Quartus (15.0) on most non-supported Linux distributions. The message does not seem to be fatal, but some tools/scripts will check the output of Quartus and...
10 years agoGood catch. But do you have libccl_curl_drl.so etc. local on your computer, e.g. in /lib64 or /usr/lib64? If yes, which versions are these?
