11 years agoInconsistency detected by ld.so: dl-close.c: 764: _dl_close: Assertion `map->l_init_c
I keep getting this message whenever I run Quartus (15.0) on most non-supported Linux distributions. The message does not seem to be fatal, but some tools/scripts will check the output of Quartus and...
10 years agoI'm using Quartus Prime Pro and Standard with the latest updates, and this issue still persists. The problem lies within the curl libraries packaged in $QUARTUS_ROOTDIR/linux64. I was able to remove ALL Quartus errors/warnings by backing up libccl_curl_drl.so, libcrypto.so.1.0.0, libcurl.so.4, libssl.so.1.0.0 and then deleting them.
sudo cp libccl_curl_drl.so libccl_curl_drl.so.bak
sudo cp libcrypto.so.1.0.0 libcrypto.so.1.0.0.bak
sudo cp libcurl.so.4 libcurl.so.4.bak
sudo libssl.so.1.0.0.bak
sudo rm libccl_curl_drl.so libcrypto.so.1.0.0 libcurl.so.4 libssl.so.1.0.0 This worked for me and allowed me to complete OpenCL compilation (finally). I also had some GLIBCXX errors, which were resolved by following the same process on libstdc++.so.6. sudo cp libstdc++.so.6 libstdc++.so.6.bak
sudo rm libstdc++.so.6 You may need to then add the i386 architecture (if on 64 Bit) and install the libraries to your system that you just removed from here. I don't remember all the commands I ran to complete this, so you may need to search a bit to find the appropriate apt-get commands to install what you removed. I fought with this issue for a week before finally working it all out!
