11 years agoInconsistency detected by ld.so: dl-close.c: 764: _dl_close: Assertion `map->l_init_c
I keep getting this message whenever I run Quartus (15.0) on most non-supported Linux distributions. The message does not seem to be fatal, but some tools/scripts will check the output of Quartus and...
10 years agoI first noticed the problem when the DDR generation script would fail. Also noted by jon_herr above. But anything which will rely on the output or maybe even return value (have not verified this yet) would fail. Unfortunately it's also present in 15.1.
