9 years agoIncompatibility Quartus 17 Pro vs 17 Standard
My understanding is that the Quartus 17 Pro edition is a new software architecture and that the only way to transfer a circuit designed within the Quartus 17 Standard environment to the Pro environme...
9 years ago --- Quote Start --- Yes, a standard project can be opened in pro. You'll get a warning that it will be converted to a pro database and that you can't go back to standard. Once in pro, you can create a .qdb file from a design partition and then import that into another pro project. --- Quote End --- Getting back to the issue of exporting a qxp file from Standard to Pro, which would be better for me, since it's just a netlist and not the source code, I could export a qxp version of my circuit in Standard. Then I could create another project in Standard using the imported qxp file. Finally, couldn't the "qxp" project in Standard be opened in Pro, so it is essentially a way of exporting a qxp file to Pro?
