Hi Mike,
--- Quote Start ---
I tried:
set my_path file join root_of_path tail_of_path
set_global_assignment -name VERILOG_FILE $my_path
This has no effect. I tried it with just the path, and with the file name.
--- Quote End ---
There's examples of how to script Quartus in this tutorial:
http://www.alterawiki.com/wiki/using_the_usb-blaster_as_an_sopc/qsys_avalon-mm_master_tutorial If you look at one of the synthesis scripts, eg.,
altera_jtag_to_avalon_mm_tutorial\hdl\boards\bemicro_sdk\qsys_system\scripts\synth.tcl
you'll see an example of how the script determines the path to the tutorial source, and then uses absolute paths in the subsequent assignments.
Cheers,
Dave
