12 years agoAn 1 bit adder has 1 AND and 1 XOR gate, so create new Block Diagram/Schematic File. Draw the circuit with its corresponding input and output ports. Save it and then from menú: File->Create Update->Create Symbol files for current file. It will create a schematic component for 1 bit adder.
Then create another schematic file and paste 1 adder 32 times. You'll find the 1 bit adder as another component clicking on the Symbol tool button. A window appears. Go to the Project folder. Select the 1 adder and use it.
