Blues-sptn
7 years agoIn the MAX 10, I / O pin state before entering user mode can be set by Quartus Prime option "Set I / O weak pull-up prior usemode". So as a question, is it possible to set weak pull-up for each pin?
In the "Set I / O weak pull-up prior usemode" setting, it is considered that individual settings can not be made because I / O excluding some are subject. .
AnandRaj_S_Intel
7 years agoHi,
<QUOTE>is it possible to set weak pull-up for each pin.</QUOTE>
All I/O pins are set to week pull up (i.e prior user-mode) during configuration (set using configuration settings).
In user mode the user I/O pins will then function as specified by your design and unused IO pins are week pull up(set using unused pin settings).
Anand
