17 years agoActually in some part of my project I need to have random numbers in exponential distribution, therefore I produce uniform random numbers using Fibonacci LFSRs and then convert it to exponential distribution by look-up table.
I need this big ROM to implement look-up table and I have to use it in the process : random_gen : process(CLK) variable qout_s : std_logic_vector(14 downto 0); variable tend1 :std_logic_vector(14 downto 0); variable tmp1 : std_logic; variable tmp2 : std_logic; variable tmp3 : std_logic; begin if (rst = '1') then qout_s := (others=>'1'); elsif (clk'event and clk = '1') then L1 : for j in 1 to 10 loop tmp1 := qout_s(2) xor qout_s(0); tmp2 := tmp1 xor qout_s(3); tmp3:= tmp2 xor qout_s(5); L2 :for i in 1 to 14 loop -- shift to right qout_s(i-1) := qout_s(i); end loop L2; qout_s(14) := tmp3; t1 : trans ( qout_s, inrand(j)); ttfs(j)<= inrand(j); end loop L1; end if; if (clk'event and clk = '0') then -- by falling edge outputs generated benchmark_2 (inrand ,clk, tsys_f ); end if; end process; --////////////////////////////////////////////////////////////////////////////////////////////////////// procedure trans ( addr :in std_logic_vector(14 downto 0); signal outdata: out bit_vector(15 downto 0)) is type rom is array(0 to 32767) of bit_vector(15 downto 0); constant mem :rom :=( "0000000101001011", --0 "0000000101101000", --1 "0000000110101011", --2 "0000101100110000", --3 "0000010001010100", --4 "0000000110001110", --5 … "0000110010001011", --32765 "0000000110000010", --32766 "0000000010011011" --32767 ); begin outdata <= mem(conv_integer(addr)); end trans; --/////////////////////////////////////////////////////// It is so nice for me to use *.mif or *.hex files instead of listing data’s in the vhdl codes!!!
