VRb
7 years agoIn Signal Tap, I have set trigger conditions on more than one signal(tapping on AXI signals). I have set to Basic AND condition on 2 signals while rest of them are don't care . Can I expect a capture correctly?
I have set Allow trigger condition changes only which will allow me to change trigger condition changes after compilation. Since I want to change the trigger condition dynamically, I am confused wit...
VRb
7 years agoHi Anand,
I have gone through the links. The video does not give a explanation of Basic AND and don't care combination.
Also, the video every time has Allow all changes in the signal tap. When this option, is set we have to recompile the entire design every time we change the control on the trigger condition.
To avoid this, we have to select the option, Allow trigger condition changes only. This allows us to change the trigger condition control at any time. This doesn't require compilation unless you bring in a new signal to tap.
I will try this out as I don't have a clear picture now and post the findings.
