16 years ago --- Quote Start --- Yes, I checked that the "Fitter Preservation Level" is set to "Placement and Routing". What is LL? What other clock routing do you mean? Does Quartus change the clock routing after importing a partition? --- Quote End --- Sorry, LL means LogicLock region. I'm not sure, but I expect that the routing to the clock input of the partition will be different. Kind regards GPK
