13 years agoImplementing firmware version
I am trying to make a code that can store firmware versions from a .txt file, I tried doing it with a ROM initialized with a .mif file, but it's not working. I have a Cyclone III that sends that info to a microcontroller and then to a HMI (human machine interface) screen so I can see the FPGA's firmware version. It's all in VHDL, but I posted this issue a few days ago and I got this reply (that seemed more appropriate, but I don't know how to do it):
--- Quote Start --- What you are attempting I have done in the past to store hardware versions and software build numbers but I had Nios II reading out the values. Perhaps you can skip using the ROM and just 'include a value defined in a verilog include file that is generated by your build system. In the include file you could just have something like 'define VERSION_NUMBER <machine generated version number> and in your hardware design refer to that value. --- Quote End --- But I've never done anything in verilog, only VHDL. I searched that out but still can't make much of it. If anyone could possibly post a code on how that's done, it would really help me, been trying to do this for long now.22 Replies
Hi Guys,
I am a newbie in tcl-scripting. I have the same problem. I am trying to use the script provided by Altera altera.com/support/support-resources/design-examples/design-software/tcl/tcl-svn-revision.html
I always get the following warning. Critical Warning: Couldn't run command to get revision number. couldn't execute "svn": no such file or directoryif { } { post_message -type critical_warning "Couldn't run command to get revision number. $msg" } else { if { -1 == $done } { post_message -type critical_warning "Timeout getting revision number." } elseif { } { post_message -type critical_warning "Couldn't find revision number in output of svn info $rootPath." } } - Altera_Forum
Ok, I have the solution !!! :cool:
In the procedure the variable "SVN" was unknown.# global SVN Variables set Glob(SVNDIR) ../MySvnPath/bin/svn.exe set Glob(SVN) "$Glob(SVNDIR)" ... proc get_subversion_revision { file_name } { global done global Glob # The maximum number of seconds to wait for the svn info # command to complete set timeout_seconds 30 # The svn info command with filename that is run set cmd "$Glob(SVN) info ${file_name}" # Attempt to get the version information. # If the command can't be run, return an error. # Otherwise set up a file event to process the command output. if { } { return -code error $input
