13 years agoImplementing firmware version
I am trying to make a code that can store firmware versions from a .txt file, I tried doing it with a ROM initialized with a .mif file, but it's not working. I have a Cyclone III that sends that info...
13 years ago --- Quote Start --- But this is not the solution I was recommending. You need to add this path to you PATH environment variable. --- Quote End --- How do I do that? I am trying this: setenv PATH ${"C:/program files/TortoiseSVN/bin"} but it gives an error: Error:can't read ""C:/program files/TortoiseSVN/bin"": no such variable I may need administrator acess on this machine to change any enviroment variable, since I'm having so many errors.
