CBrow36
7 years agoI'm wondering is whether there is a way to generate or not generate the jbc file based on an environment variable. Any ideas? I'd like to not create a jbc when I don't generate ALTPLL to speed simulation.
What started as a design workaround when I found that ALTPLL in Verilog was broken is also useful in simulation. I feed an external clock into the simulator and don't instantiate the PLL and it runs...
sstrell
7 years agoThe easiest thing would be to not have the Assembler, which generates the file, run during a full compilation. In the Pro edition, you can click a checkbox in the Compilation Dashboard, but in the Lite edition, go to Project menu -> Settings -> Compilation Process Settings and turn off "Run Assembler during compilation."
When you do need to generate the file, just run the Assembler manually from Processing menu -> Start -> Start Assembler.
#iwork4intel
