MSura2
6 years agoI'm unable to run the counter example on the FPGA, I'm running the command: make test-fpga.
command: i++ counter.cpp -v -march=Arria10 -o test-fpga Output: Target FPGA part name: 10AX115U1F45I1SG Target FPGA family name: Arria10 Target FPGA speed grade: -1 Analyzing counter.cpp for t...
AnilErinch_A_Intel
5 years agoHi ,
The Arria10 device support need to be enabled in the Quartus and the license of Quartus also should not have expired.
To install Arria10 device you have to download the QDZ file corresponding to the device first. Then open Quartus and go to Tools->Install Devices and select the QDZ file of your choice. Then try running the HLS programs again.
Thanks and Regards
Anil
