9 years agoi'm in trouble, i can't find my fault wiht 10500errors help me
-----------------------------------------------------------------------lcd----------------------------------------------------- library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsign...
9 years agoAs a general note, when you end up with a big list of errors you're probably forgetting to close an expression with a comma or a semicolon. Check the first error at the lowest line number and your problem is *probably* going to be around there.
