9 years agoi'm in trouble, i can't find my fault wiht 10500errors help me
-----------------------------------------------------------------------lcd----------------------------------------------------- library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsign...
9 years agocould you edit your post so the code is in code tags and keeps the indentatio s etc? that makes it more readable. having said that, then you should check just before line 152, you probably forgot so mething like an end statement, as the error is telling you it expected before it saw the when.
