CKiel
7 years agoim am trying to Build a 8-bit to 16-bit left combinatorial shifter using the IF-THEN statements and im getting errors
the specifications are athat is shift cntrl =0 then no shift if shift cntrl = 1 then shift 4 to the left, if shift cntrl =2 then shift left 8 and if shift cntrl=3 then no shift my current code is ...
Vicky1
7 years agoHi Cameron,
Please follow the VHDL syntax,
Replace the single quote(' ') with double quotes(" ") since bit_vector literal is an array of bits & that should be enclosed in double quotes.
Vikas
