8 years agoIf loop with parameters.
I have this bothering me for quite some time now. I make a simple loop with ifs to create a state machine, where I just want stuff to happen in a certain order after some flags are activated. ...
ricardoluz
8 years ago(I am the author of this question)
I think I first used case instead of ifs, and then started using ifs because of this exact problem but got the exact same issue.
I'm using a 320 MHz PLL in this module (the fastest clock I use in my design) but I fill all timing requirements in time quest.
Do you think that might influence it anyway?
