-- Port Declarations --
entity I2C_Controller is
GENERIC(
input_clk : INTEGER := 50_000_000; --input clock speed from user logic in Hz
bus_clk : INTEGER := 400_000); --speed the i2c bus (scl) will run at in Hz
port (
-- Inputs
clk : in std_logic;
reset_n : in std_logic;
address : in std_logic_vector (2 downto 0);
we : in std_logic;
byte_enable : in std_logic_vector (1 downto 0);
rd : in std_logic;
data : in std_logic_vector (31 downto 0);
-- Bidirectionals
I2C_SDAT : inout std_logic;
-- Outputs
acknowledge : out std_logic;
I2C_SCLK : out std_logic;
read_data : out std_logic_vector (31 downto 0);
--SRAM_ADDR : out std_logic_vector (17 downto 0);
--SRAM_CE_N : out std_logic;
--SRAM_WE_N : out std_logic;
--SRAM_OE_N : out std_logic;
--SRAM_UB_N : out std_logic;
--SRAM_LB_N : out std_logic
end I2C_Controller;
architecture I2C_Controller_rtl of I2C_Controller is
CONSTANT Period_Count : INTEGER := "126";
CONSTANT HALF_PERIOD_COUNT : INTEGER := "63";
type State_type is (idle,reads,writes);
signal current_state, next_state: state_type;
begin
process(clk,reset_n)
VARIABLE count : INTEGER RANGE 0 TO divider*4;
begin
if (reset_n = '0') then
current_state <= idle;
elsif (clk'event and clk = '1') then
current_state <= next_state;
end if;
end process;
process(bus_enable,rw,current_state,address,I2C_SDAT,write_data)
begin
case current_state is
when idle =>
acknowledge <= '0';
SRAM_CE_N <= '1';
SRAM_OE_N <= '1';
SRAM_WE_N <= '1';
read_data <= (others => 'Z');
SRAM_ADDR <= (others => '0');
I2C_SDAT <= (others => 'Z');
if (bus_enable = '1') then
if (rw = '1') then
next_state <= reads;
else
next_state <= writes;
end if;
end if;
when reads =>
SRAM_ADDR <= address (17 downto 0);
SRAM_CE_N <= '0'; --chip enabled
SRAM_OE_N <= '0'; --read enabled
SRAM_WE_N <= '1'; --write disabled
read_data <= I2C_SDAT;
acknowledge <= '1';
next_state <= idle;
when writes =>
SRAM_OE_N <= '1'; --read disabled
SRAM_WE_N <= '0'; --write enabled
I2C_SDAT <= write_data;
acknowledge <= '1';
next_state <= idle;
end case;
end process;
process(byte_enable)
begin
if byte_enable = "00" then
SRAM_UB_N <= '1';
SRAM_LB_N <= '1';
elsif byte_enable = "01" then
SRAM_UB_N <= '1';
SRAM_LB_N <= '0';
elsif byte_enable = "10" then
SRAM_UB_N <= '0';
SRAM_LB_N <= '1';
else
SRAM_UB_N <= '0';
SRAM_LB_N <= '0';
end if;
end process;
end I2C_Controller_rtl;
