11 years ago
i want to set time with keypad or keyboard using DE2 board
hello
i got the digital clock using vhdl. but my code is to set the time with switches.
i want to set the time by using keyboard or keypad.
so, i think i don't have many things to change in my VHDL coding.
but i have no idea to work with keyboard or keypad.
if you know about that plz help me...........
    First, how do you connect the keyboard or keypad. Just buttons is easiest. For each button a GPIO pin and then you could just read that. Another option is to use protocols like PS/2 or USB. I have some experience in designing hardware for PS/2 and if you only want to read the design is relatively simple. I have no idea how to use USB. There might be a design in the IP catalogue you can use.
    thank sir
    but i don't know how to write VHDL code for this time set with keypad or keyboard.
    if you don't mind, can you explain me more? no matter ps/2 or usb sir
    Well, you have a module that reads input from the keyboard/pad.
    You will have to find out which type of character encoding is used and than you have to convert this to a number.
    This number can be used as input to set the time.
    thanks sir
    can you share me the link to read.
    i don't know where i can get it.
    I don't have any links to this. I have some books on my shelf concerning protocols etc.
    But I imagine you'll find the same information if you use your favorite web search engine.
