PWalk14
6 years agoI want to generate a .vhd file to load UFM (parallel - read only) with data in Quartus 2 using the wizard. The generated file does not contain the data
Quartus 2 v13.0.1 SP1 Megawizard generating parallel UFM I want to load the UFM in a EPM240 CPLD with data to be used for a look-up table. I have finally found the required format (Tab delimited) ...
JohnT_Altera
6 years agoHi,
I would recommend that you follow the memory block that you initiated in order to create the mif or hex file so that it is able to initiate into the memory block correctly.
