PWalk14
6 years agoI want to generate a .vhd file to load UFM (parallel - read only) with data in Quartus 2 using the wizard. The generated file does not contain the data
Quartus 2 v13.0.1 SP1 Megawizard generating parallel UFM I want to load the UFM in a EPM240 CPLD with data to be used for a look-up table. I have finally found the required format (Tab delimited) ...
JohnT_Altera
6 years agoHi Phil,
May I know if you have any other issue regarding this memory initialization issue?
