PWalk14
6 years agoI want to generate a .vhd file to load UFM (parallel - read only) with data in Quartus 2 using the wizard. The generated file does not contain the data
Quartus 2 v13.0.1 SP1 Megawizard generating parallel UFM I want to load the UFM in a EPM240 CPLD with data to be used for a look-up table. I have finally found the required format (Tab delimited) ...
JohnT_Altera
6 years agoHi,
May I know which Quartus version are you using? Could you share with me your Quartus rpt file which is generated after Quartus compilation? Please also share with me your .hex file and exact device that you are using so that I can help to generate the file to see if I am able to observed the same issue.
PWalk14
6 years agoTrying 1 byte per line as generated by 'File' process:
Firstly try to attach .hex file - seems to have worked so here it is
Phil
