10 years agoi wanna to convert this code in vhdl
void main() { SerialPortInit(); /* Serial Communication – 9600-N-8-1 */ Send2Gsm("AT\r\n"); /* Transmit AT to the module – GSM Modem sends OK */ DelayS(2); /* 2 sec delay */ Send2Gsm("A...
10 years agoMy reply about the code not being synthesizable was intended as a note, just something to keep in mind. I should have stated this.
If you don't want to use a softcore like NiosII you will have to think about which hardware components you need. I see an rs-232? and depending on the devices you use to send the GSM signals you will need to implement an interface for this as well.
