MAlas1
6 years agoI need the way to add unisim library or library like it.
this is the error "Error (10481): VHDL Use Clause error at clk_wiz_0_tmp.vhd(72): design library "unisim" does not contain primary unit "vcomponents". Verify that the primary unit exists in the libra...
ahaa
5 years agoHave you solved this problem? I meet the same question now ,and when I copy unisim vhdl library from vivado to quartus library, but more detail errors were reported and some previous errors.
Do you have some suggestions or solutions?
Thanks very much!
